Hi peeps!
Turns out it was running way too much advance when it ran well, and was way retarded when it started fine ( does this sentence make sense?)
Timed in @ 6° and it ran quite smooth ( need to fiddle with the mixture a bit more) . Didn't get too hot now ( normal temperature on the gauge) and oil pressure was around 45 psi at 2K rpm no ( wich I think is good?)
Feels a bit better already. Although the engine did cut out suddenly, but that was due to the coil comming loose ;p
cheers
