Stuck Tappet
13 replies to this topic
#1 bobbym18
bobbym18
  • 198 posts
Posted 26 May 2015 - 05:09 PM
Hi all,
I went to adjust my valve clearances today after refitting the rocker after changing the cylinder head recently. I noticed that the number 3 push rod was a couple of centimetres higher than the rest.
I took the tappet cover off the back, after a lot of fiddling, and found the tappet was higher than the others. I took the tappet out and put my finger in the hole to see if something had fallen in but all i could feel is what i believe is the cam shaft?
I stuck a magnetic screwdriver down to be sure but there was nothing.
I tried putting the car in gear and pushing to try and get some movement to see if it helped but nothing happened. Ive read an old thread on here and things dont sound good :S
Any help appreciated.
998cc 1986 mini city
#2 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 26 May 2015 - 05:22 PM
This happened to me before when removing the push rods. One of the tappets came out of it sleeve/hole and when refitting the push rod it was higher than the rest. Just take the tappet out and put it back in. Making sure you put it in the right way. Flat side down and open end upwards. Refit push rod and see what it's like
Dan
#3 bobbym18
bobbym18
  • 198 posts
Posted 26 May 2015 - 05:35 PM
I have done that. I've had the tappet out, cleaned it of any debris and put my finger down the hole, put the tappet back in but still higher, I've tried this about 3 times :/
#4 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 26 May 2015 - 05:50 PM
How much higher ? As the tappets won't all be at the same height ? As the cam lobes highest point are all in different places
Dan
#5 bobbym18
bobbym18
  • 198 posts
Posted 26 May 2015 - 05:56 PM
It was about 2 cm. it was so high I couldn't push the rocker all the way onto the head.
#6 Spider
  • 15,025 posts
Posted 26 May 2015 - 07:22 PM
Someone hasn't previously fitted a 1275 pushrod in to that tappet? They are about 3/8" (10 mm) longer than all others. There is also another early pushrod that's a little longer (about 4 mm) than the later ones too, but off hand, I can't recall what these were fitted to.
#7 bobbym18
bobbym18
  • 198 posts
Posted 26 May 2015 - 08:21 PM
No it's definitly the correct push rod. It's the tappet that isn't going down as far as it should
#8 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 26 May 2015 - 08:31 PM
If that valve is on full or partial lift it will be like that.
#9 bobbym18
bobbym18
  • 198 posts
Posted 26 May 2015 - 08:39 PM
so do you think i should just pop the car in gear and try turning it over more?
when i tried last time there seemed to be little movement from any valves. Could there be a problem with the cam shaft?
#10 spiguy
spiguy
  • 1,537 posts
Posted 26 May 2015 - 09:20 PM
how far did you move the car with it in gear?  It would take a few feet of car movement to do much if it's in 4th gear.
#11 bobbym18
bobbym18
  • 198 posts
Posted 26 May 2015 - 09:25 PM
I moved it probably 7 feet or so. the tappet just didnt seem to move at all
#12 bobbym18
bobbym18
  • 198 posts
Posted 28 May 2015 - 07:35 PM
any ideas?
#13 mini danny
mini danny
    I am a mini daddy.
  • 5,229 posts
Posted 28 May 2015 - 08:52 PM
Take the plugs out and move the car forward with it in gear and see if goes down at all ?
Dan
#14 Gremlin
Gremlin
  • 2,142 posts
Posted 28 May 2015 - 11:00 PM
It may not fall on it's own while turning over, you may have to keep stopping and pushing it down with your hand
