Seam Sealer
7 replies to this topic
#1 Hendred
Hendred
  • 484 posts
  • Location: Cleobury Mortimer Nr Ludlow, Shropshire Name: John
Posted 03 June 2015 - 10:21 AM
Hi all,
Anyone use welding seam sealer?  What are the pros and cons?  Does it hold moisture?
I sometimes have very small pin holes that this would solve, I notice that it was used in original manufacture.
Comments and experiences please
Thanks John
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 03 June 2015 - 10:25 AM
If you mean, does anyone seam seal their welds, then yes, I always do.
#3 Carlos W
Carlos W
  • 10,114 posts
Posted 03 June 2015 - 10:26 AM
I like the mig welding forum for stuff like this
http://www.mig-weldi...eam-sealing.htm
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,089 posts
  • Name: Neil
Posted 03 June 2015 - 10:30 AM
If you have pin holes then they need to be filled with weld. No point in sealing them.
The best method i find with dealing with these is where possible shine a light behind the welded area, mark the pin holes then weld them up.
#5 Hendred
Hendred
  • 484 posts
Posted 03 June 2015 - 12:47 PM
Great thanks for the advice guys and link.
#6 Hendred
Hendred
  • 484 posts
Posted 03 June 2015 - 01:21 PM
Just had a go, used masking tape to get a neater edge, haven't done up as far as pin holes as I will weld them up as suggested.
It will hardly notice once painted.
#7 Carlos W
Carlos W
  • 10,114 posts
Posted 03 June 2015 - 01:44 PM
Dipping the paint brush in thinners before applying the seam sealer can give a good finish.
#8 castafiore
castafiore
  • 116 posts
Posted 03 June 2015 - 02:46 PM
I do the same as Sonnik and shine a light behind the weld to see the pinholes. I then prime, then usually use Upol grey stripe which is a good brushable seam sealer, then prime again. Tiger Seal is very good too, when you want a thinner more accurate bead.
Edited by castafiore, 03 June 2015 - 02:47 PM.
