Clutch Reservoir Cap Replacement
5 replies to this topic
#1 Toeknee
Toeknee
  • 59 posts
Posted 04 June 2015 - 11:34 AM
Hi, potentially (another) silly question but here goes...  I managed to break my clutch reservoir cap in two when I was fitting a new air filter. I found and bought a replacement from Mini Spares, which is identical except the thread seems different and it won't fit. >_<
Has anyone else hit this problem before?  I've found alternative suppliers but the caps are all appear the same as the replacement I've already got....  currently considering super-gluing the old cap back together but I'd rather fit a new one, if possible
#2 Wiggywithahailo
Wiggywithahailo
  • 505 posts
Posted 04 June 2015 - 11:52 AM
The centre can sometimes come out of the cap have you tried pushing it back in?
#3 Toeknee
Toeknee
  • 59 posts
Posted 04 June 2015 - 09:32 PM
Cheers for the response, Wiggy. Mine doesn't have a centre to to push back in?  This was the replacement: MiniSpares.  As I say, its identical in every possible shape and size except the thread...
Just a bit stumped how to get round it without having to fit an entirely new master cylinder for the sake of a £3 cap. Hmmmn
#4 Spider
  • 15,684 posts
Posted 04 June 2015 - 10:15 PM
Bummer.
Do you have a plastic tank on yours?
Perhaps in the short term, glue it back together, but I think your best option for a replacement cap would be to look second hand.
#5 GraemeC
GraemeC
  • 7,467 posts
Posted 05 June 2015 - 07:00 AM
The recent ones do seem to have a crap thread on them. but usually fit with a bit of patience.  You need to inspect the thread and see if there is any flashing or bad moulding that needs filing away.
#6 Toeknee
Toeknee
  • 59 posts
Posted 05 June 2015 - 04:53 PM
Good advice. I'll have another bash at fitting the one I've got, if not I'll glue the old one as a temp measure... On the brightside, replacing the master cylinder will be a good learning experience. Thanks all.
Edited by Toeknee, 05 June 2015 - 04:54 PM.
