Project Sell Up - 998 Turbo
27 replies to this topic
#1 smit360
smit360
  • 43 posts
Posted 06 June 2015 - 11:48 PM
Due to work commitments, I’ve regrettably decided to sell my 998 turbo project. I had it running on the road briefly naturally aspirated for about 100 miles but just haven’t got the time available that I want to put into it. I’ll be braking the car for parts with everything available, unsure of the best way to sell the shell i.e rolling with sub frames and wheels or on its own etc. However, the following parts are not fitted or i’ve removed already:
998 fully stripped and rebuilt engine: This can come complete with benross 12G940 head or without. Has only covered 100 miles since rebuild.
  • 998 Morspeed A+ block, bored +30 and pocketed for 12G940 head
  • Powermax pistons possibly (couldn’t find any numbers on them which gave me any relevant information)
  • Wedged and cross drilled crank
  • MG metro cam and new followers
  • New waterpump, smaller pulley to clear head (100 miles from new)
  • Metro turbo oil pump modified to suit and extra fixing hole drilled and tapped in block (100 miles from new)
  • New mains +10, Big ends +10 (100 miles from new)
  • Verto performance clutch cover C-AEG485, performance clutch plate C-AHT596 (100 miles from new)
  • Duplex chain and rota slide steel gear set (100 miles from new)
  • Clutch arm, slave cylinder and braided hose (100 miles from new)
  • Gearbox stripped, rebuilt using genuine rover baulk rings, new roller double bearing, central oil pickup (100 miles from new)
  • Minispares x-pin diff (100 miles from new)
  • 3.44 CWP
  • 1275 timing cover to utilise breather and flywheel breather added as tappet chest breather removed
  • All gaskets replaced
There is probably more, but that’s what I can remember off of the top of my head, endless receipts for all the parts bought.  If enough interest in individual parts I will consider splitting. I’m unsure on what to value this? It’s ran with no issues n/a for 100 miles. Pulled fairly well considering it was built with the intention of turbo use and 8.5:1 compression ratio.
Benross cylinder head – covered 100 miles naturally aspirated = £500
Spec as followed:
26ccs in the combustion chamber
inlet valves are 33mm plasma nitride 214N stainless race valves
29.5mm plasma nitride 214N stainless race valves
manganise valve guides, Dupont top quality seals
fully ported, for optimum flow and gas speed
3angled seats on the inlets
45degree seats exhaust with satellite hardened inserts for unleaded fuel
Hasterloy inner retainer spring retainers
180 pound double race valves coping with lifts of 0.570" and revs +8000rpm with no valve bounce
Air filter pipework – new, unused = £10
Maniflow 2” link pipe and back box – used but good condition = £50
TIM gauges – All new, Electric water temp, Amps, Boost (1 bar,) Mechanical oil pressure. All boxed, all be it some boxes a little old = £25 each posted
Alloy fuel tank – used for 100 miles, outlet, return and overflow. Possibly has an internal swirl pot? = £100
Minisport 7.9” gold alloy calipers with vented discs – Covered 100 miles = £300
Postage now incorporated into prices where shown.
I am open to offers on all items, but no major rush to sell.
Edited by smit360, 02 July 2015 - 09:42 PM.
#2 james.c94
james.c94
  • 164 posts
Posted 07 June 2015 - 12:11 AM
Pm'd
#3 bluemini1979
bluemini1979
  • 619 posts
  • Local Club: Colchester Mini Club
Posted 07 June 2015 - 06:46 AM
How much posted for the inlet manifold. Have you got the abutment plate for the carb?
#4 smit360
smit360
  • 43 posts
Posted 07 June 2015 - 08:26 AM
Bluemini: Added photo's now, forgot to mention about the water pipes being removed! If you would still like it let me know. Sorry no abutment plate.
#5 rob mini
rob mini
  • 1,420 posts
Posted 07 June 2015 - 12:38 PM
Are the dampers the lowered model?
Do you have the original wiring loom, is it in good shape?
#6 smit360
smit360
  • 43 posts
Posted 07 June 2015 - 04:01 PM
Rob: the dampers have now sold, sorry. Wiring loom may be going with shell, ill update you on that.
#7 Steve220
Steve220
  • 5,063 posts
  • Local Club: BMC
Posted 07 June 2015 - 05:40 PM
Turbo, manifold and downpipe delivered? Very interested :)
#8 smit360
smit360
  • 43 posts
Posted 07 June 2015 - 06:50 PM
Hi Steve, still available and can post. PM me if interested, thanks.
#9 Steve220
Steve220
  • 5,063 posts
  • Local Club: BMC
Posted 07 June 2015 - 07:27 PM
I am interested. Please PM me with your best price :) I MAY be able to pick them up depending on where you are in Staffordshire :D
#10 smit360
smit360
  • 43 posts
Posted 07 June 2015 - 08:01 PM
PM'd Steve.
#11 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 08 June 2015 - 07:19 PM
I'd like the flouro lined oil hose please. How much posted ?
Phil.
#12 smit360
smit360
  • 43 posts
Posted 08 June 2015 - 09:53 PM
Hi Phil,
say £12 posted?
Rob.
#13 Turbo Phil
Turbo Phil
  • 2,426 posts
Posted 09 June 2015 - 06:49 PM
Hi Phil,
say £12 posted?
Rob.
Done ! PM me your payment details. Cheers !
Phil.
#14 smit360
smit360
  • 43 posts
Posted 09 June 2015 - 07:00 PM
PM'd
#15 Lucas1988
Lucas1988
  • 410 posts
  • Local Club: Frome Mini Club
Posted 09 June 2015 - 08:38 PM
Have you got a price that you want for the shell?
