Crankshaft Oil Seal Tool
6 replies to this topic
#1 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 08 June 2015 - 05:58 PM
Is the crankshaft oil seal fitting tool needed or can you DIY one? got the engine out and in bits to replace it but didnt know if it was worth spending £25 or so on a tool I will probably only use once or if a simialr tool can be made from old tubes.
Also when exposing the old oil seal it has silcon sealant smeared around it... Im guessing someone tried to botch the leak up at some point or are you suposed to put some sealant on as well?
#2 Gr4h4m
Gr4h4m
  • 1,802 posts
  • Local Club: Club less.....
Posted 08 June 2015 - 06:08 PM
Sounds like the tried to stop a leak. The tools are good in terms of ensuring the seal is installed square ame the splines don't damage it when it's being installed. But you can install them without the tool
#3 59 Speed
59 Speed
    Formally know as Smackfiend
  • 674 posts
Posted 08 June 2015 - 06:30 PM
As I'm a cheapskate I didn't buy a tool - but then went through 2 uprated seals trying to "Tap them in" square :-|
I got the seal over the splines using masking tape and plenty of lube but struggled to get the outer edges in without damaging the rubber covering the steel part.
Ended up making a tool to get it in properly:
Attached File  image.jpg   39.45K   8 downloads
Attached File  image.jpg   51.79K   12 downloads
I'm sure you can make one out of steel tubing etc... Just make sure you don't damage the seal with any sharp edges.
#4 Spider
  • 15,053 posts
Posted 08 June 2015 - 08:51 PM
A mate of mine made a tool similar to Smackfiend's out of some PVC Plumbing Pipe fittings. Easy, Cheap and has done the job for him a few times now.
#5 beardylondon
beardylondon
  • 1,601 posts
Posted 09 June 2015 - 04:17 PM
hi all,
I am about to do my driveshaft oil seals.  apart from a scissor type ball joint splitter, what other tools would I need?
Is there a proper tool you can buy to fit the new seal?
I see you made one, which I can try, but what are the dimensions of the tool?
thanks!
#6 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 09 June 2015 - 05:54 PM
that looks good, I will try make that :) what thread is the flywheel bolt as Im guessing I need a long one of these  thanks
#7 59 Speed
59 Speed
  • 674 posts
Posted 09 June 2015 - 08:13 PM
I just used the normal Verto flywheel bolt
