Diff
7 replies to this topic
#1 spritey
spritey
  • 162 posts
Posted 10 June 2015 - 12:07 PM
How do you tell what diff you have e.g 3:44 . Thanks
#2 Alex_B
Alex_B
  • 4,573 posts
Posted 10 June 2015 - 12:17 PM
The number 3.44 is the ratio of turns between the crown wheel and pinion. 3.44:1 for instance.
So count up the number of teeth on the crown wheel, and the same on the pinion and then that will give you the ratio.
Alternatively I think the teeth numbers are sometimes stamped on the gears, saves you counting.
Obviously you will have to strip off the diff casing to get to the internal components to check this.
#3 Midas Mk1
Midas Mk1
  • 5,788 posts
  • Local Club: S.U.N.M.C
Posted 10 June 2015 - 12:37 PM
Got a rev counter? Just see what revs you're doing at a satnav proven speed, e.g at 3000 revs in 4th. Using guessworks calculator you'll be able to see what ratio it has
#4 spritey
spritey
  • 162 posts
Posted 16 June 2015 - 05:19 PM
I've got diff and it says 19/59 on it ,
#5 spritey
spritey
  • 162 posts
Posted 16 June 2015 - 05:22 PM
#6 Midas Mk1
Midas Mk1
  • 5,788 posts
divide 59 by 19..
#7 gazza82
gazza82
  • 3,020 posts
  • Local Club: TMF+
Posted 17 June 2015 - 08:54 AM
divide 59 by 19..
3.1
#8 Spider
  • 15,160 posts
Posted 17 June 2015 - 08:57 AM
divide 59 by 19..
I don't have that many fingers!
Even if I take my socks off,,,,,
Edited by Moke Spider, 17 June 2015 - 09:00 AM.
