Clutch Disc Size
5 replies to this topic
#1 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 10 June 2015 - 12:52 PM
Can a 190mm clutch disc be fitted to a 998? The current one is 180mm but it looks like a 190mm could be fitted after measuring the flywheel and pressure plate surface ( it measures about 192mm ) or is that gap there for a reason?
#2 Cooperman
  • 23,322 posts
Posted 10 June 2015 - 02:38 PM
There doesn't seem to be any dimensional reason why the 180 mm & 190 mm clutch plates cannot be interchangeable although I've never done it.
For a 998 there would be no advantage and even the Turbo engine cars (Metro) only use a 180 mm.
In fact, the 190 mm might well need a stronger diaphragm spring to make the contact pressure per sq. mm. correct.
#3 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 10 June 2015 - 10:23 PM
Could an ap turbo clutch plate be used on a 998?
#4 nicklouse
  • 18,679 posts
Posted 10 June 2015 - 10:27 PM
I would look to a stronger diaphragm before the plate.
#5 Cooperman
  • 23,322 posts
Posted 10 June 2015 - 10:48 PM
It's high torque which kills clutches and/or a high 1st gear. A 998 is unlikely to suffer from that.
#6 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 11 June 2015 - 06:19 AM
So do you think an AP clutch plate for a Turbo would be ok (180mm) only asking realy as it seems to be £12 cheaper than a normal plate....
