Drive flanges and discs not fitting
6 replies to this topic
#1 jimini
jimini
  • 40 posts
Posted 26 July 2006 - 09:13 PM
Im finnishing off a 10" disc conversion, the problem i have is the new drive flanges and discs arnt fitting together, theres at least 2mm betwen the mateing surfaces no matter how hard i hit it . Any one else had this problems. Any sugestions????
many thanks
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 July 2006 - 09:24 PM
Pictures? There's nothing really that can stop the two fitting together as long as both parts are the same type.
#3 jimini
jimini
  • 40 posts
Posted 26 July 2006 - 09:34 PM
Ill try and get pics tommorow... They came from the minisport 10" conversion kit, I only noticed the problem when everything was assembled the back of the disc rubbed the hub assembly
#4 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 26 July 2006 - 09:42 PM
Rubbing the hub or rubbing the steering arm?
And if these are OE type 7.5" discs and flanges do you have the correct type hubs?
Edited by Dan, 26 July 2006 - 09:43 PM.
#5 jimini
jimini
  • 40 posts
Posted 26 July 2006 - 10:00 PM
The Hub assembaly was orignaly from a an 8.4" set up. It rubs against the flatt bit that sticks out by the bottom ball join grease nipple???
#6 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 26 July 2006 - 10:04 PM
which parts have come from Minisport and which parts have you retained from the original set up. What was your original set up?
#7 jimini
jimini
  • 40 posts
Posted 26 July 2006 - 10:06 PM
The kit from minisport came with flanges discs and calapers the rest was from an 8.4 setup
