Loud Knocking Noise When Turning
6 replies to this topic
#1 SamuelSanders
SamuelSanders
  • 11 posts
Posted 13 June 2015 - 09:22 AM
Hi there
First of all, I drive a 1993 Rover mini Rio 1275. A little while ago when turning on full lock, a clicking noise could be heard and unfortunately I just ignored it as it wasn't actually causing me a problem at the time. However, the problem has escalated to the point where I can't even full lock right/left and move because it makes a really loud banging/knocking noise and it tries to throw my steering wheel back to the centre. I don't fight it, I just have to just turn very delicately.
I've been advised its likely to be my CV joints that need replacing. Does this sound about right?
If so, would this be the inner/outer CV joint?
Any questions please ask and I will try to answer.
Regards
Sam
#2 spiguy
spiguy
  • 1,537 posts
Posted 13 June 2015 - 09:34 AM
Sounds like outer CV Joints. I've never had them deteriorate to that extend mind you. Usually just clicky. Does it try to self centre regardless of going left or right? Was it initially only happening on either turning right or turning left?  For such serious wear, I would have expected that to be caused by failure of the CV on one side - could be one of the balls in the CV had come out (maybe even dropped out if the gaiter is split) or maybe the cage that holds them has cracked.
Usually the CV that clicks is the one on the wheel at the outside of the turn (so left side going right and vice-versa). The self centre thing is probably because the wheel is dragging as the CV partially locks up, which will have the effect of braking that wheel only. Imagine it's just the left CV that has failed badly - in this case I would expect it to self centre when going right, but actually be harder for you to centre when going left. Opposite argument applies if it is the right CV with the serious failure. If you are saying it self centres and bangs when going left or right, that would mean both sides had failed seriously. Could be I guess, but I would have thought unlikely.
In any case, get under and have a look. I suspect you will find a split gaiter on one / both CV's. Farily cheap part to replace, and not too difficult. Would you be doing the job yourself?
EDIT: Even if you do find a split gaiter, that is not the cause of the serious problems you are having, just in case you think I mean just change the gaiter.... I meant it has probably split letting all the grease out and dirt in, and accelerating the wear of the CV joint, which will itself need replaced.
Edited by spiguy, 13 June 2015 - 02:32 PM.
#3 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 13 June 2015 - 10:13 AM
Don't want to be an alarmist but it is possible for the cv cage to split and lock the cv joint and making steering bad. My suggestion is find out what it is and fix it asap.
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 13 June 2015 - 12:36 PM
yep
#5 spiguy
spiguy
  • 1,537 posts
Posted 13 June 2015 - 02:30 PM
Indeed. Sounds like a severe failure of one or both (probably one) of the CV joints. Fix it before it locks solid on you!
#6 Cooperman
  • 23,340 posts
Posted 13 June 2015 - 05:57 PM
Best advice is not to drive it until the problem is identified and fixed. A total CV joint failure can cause a loss of control.
#7 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 13 June 2015 - 06:11 PM
+1
