getting those pot joints back in the g/box
Posted 26 July 2006 - 10:48 PM
Posted 27 July 2006 - 06:20 AM
Posted 27 July 2006 - 06:44 AM
hey guys, taken out old drive shafts hub etc including the pot joint assembly and i cant get the new ones in! any tips?
On a recent engine swap we couldn't get the pot joints to go in, no matter how hard we tried. Removed the little circular clip to find it was somewhat oval... re shaped it to a near circle and refitted and the pot joint went on with the first hammer tap.... and locked in place...
Try that....
Carl.
Posted 27 July 2006 - 04:06 PM
Posted 27 July 2006 - 04:20 PM
Posted 27 July 2006 - 04:21 PM
the only thing is the drive shafts etc are all attached! can i just take the boot off and pull all the shaft out to leave the pot empty, then wack it? tried pushing from hub end but no go! what part am i meant to be hitting . . surly i need to removve boot so i dnt split it. haynes talks of a worm drive . . what the hell is one of those?
Its like a jubilee clip, it means so you have something to knock the hammer against to get it in. the way i have always done it is to offer up the whole assembly support in on blocks etc and then place a wooden block on the hub the wack that with the lump hammer until it goes in. The ideal way is to remove the end of the driveshaft from the pot joint and then hit that directly. I did this (as its awkward to get a good swing) by placing a series of blocks of wood that emerged through the hole in the subframe, and then swinging the hammer round, it will go in like this.
Posted 28 July 2006 - 09:49 AM
