Gearstick Problem And Engine Oil Advice
23 replies to this topic
#1 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 07:46 PM
Came to the conclusion that the gear box might need a look at, the problem is that when you go from 3rd to 2nd (when the speed is above about 18/20mph) it makes a sorta grating sound? But it makes no grating noise when at a slower speeds..
Wondering if its better to get the gear box reconditioned by a professional company or to buy another one and have someone fit that into the car? Or would I be better off just driving slower then changing into second making no grating sound at all?
Secondly my cars engine is from 1993 BUT the actual mini it is in is a 1973, so it has no CAT, what engine oil is recommended? I've been told 20w50, 10w40 or 10w50...just wondering which is best?
Thank you for reading!
#2 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 15 June 2015 - 07:51 PM
double declutch?
https://en.wikipedia.../Double_clutch_(technique)
#3 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 07:53 PM
double declutch?
Thats something I'll try, thanks for the tip
#4 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 15 June 2015 - 08:01 PM
Its a way to get around worn synchromesh, its quite fun to perfect anyway
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
The crunch is due to the baulkring wearing out, this is just a fact of life, and will need sorting sooner or later...
You can get around it by double-de-cluching but everytime you miss, every crunch is a little more off the dog teeth of the second gear, which eventually will also need replacing, additional costs....
As for what oil... may the debate commence, however, IMO I really does not matter too much what oil you use as long as you change it regularly, but I would suggest a mineral 10w40,15w40 or 20w50.
#6 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 15 June 2015 - 08:02 PM
20W50 Valvoline or Millers oil. Millers produce a specialist oil for mini engines. :D  :highfive:
#7 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 08:05 PM
Is the baulking something that can be repaired on its own without having to re-do the whole gear box? How much would it cost?
Edited by Notepad12, 15 June 2015 - 08:05 PM.
#8 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 15 June 2015 - 08:07 PM
No, whole gearbox apart to change baulkrings ( there's 4 altogether in your gearbox - one for each gear )
Costs start @ £129
#9 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 08:10 PM
Costs start @ £129
Are there any places near Sussex/London that would do that sort of work?
Edited by Notepad12, 15 June 2015 - 08:10 PM.
#10 Anthony30
Anthony30
  • 1,467 posts
  • Local Club: N/A
Posted 15 June 2015 - 08:12 PM
No point in penny pinching to be honest. You either want it done cheap or right. :shy: The baulk rings are made to wear anyhoo, so the sooner you get the problem sorted the better.
#11 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 15 June 2015 - 08:20 PM
Costs start @ £129
Guessworks is the man to be honest even if you need to ship it :)
#12 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 08:22 PM
Costs start @ £129
Thats a fair distance, I'll have a look at somewhere closer before considering that one, but thanks!
Edited by Notepad12, 15 June 2015 - 08:23 PM.
#13 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 08:32 PM
As for oil Halford's recommend 20w50 but GC Motors in Kent (all they do is classic mini sales) use 10w50..much of a difference between them two?
Edited by Notepad12, 15 June 2015 - 08:32 PM.
#14 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,839 posts
Posted 15 June 2015 - 08:43 PM
Costs start @ £129
Try Kevin @ Sussex road and race
#15 Notepad12
Notepad12
  • 160 posts
Posted 15 June 2015 - 09:44 PM
Costs start @ £129
Thanks for pointing him out,
Does anyone have any idea how much it'd be to get the baulk ring repaired?
