Cooper Head
Posted 27 July 2006 - 08:56 AM
Someone in the for sale section has a low mileage, cooper head for sale. Other details are unknown.
As its a 998 head, can I just bolt it on to my std 998 and expect a slight performance increase.
Probably a good idea to ask for the casting no. !
Oh and does £60 sound like fair dos ?
James
Posted 27 July 2006 - 08:57 AM
It will give a slight performance increase over a standard small bore head.
Check the head number.
Posted 27 July 2006 - 09:00 AM
Will probably get it reconditioned by my local chaps if I go ahead. Any ideas on how much needs skimming off ?
Posted 27 July 2006 - 09:03 AM
Shhhhh, this isn't a reputation I want spread around!Thanks Jammy, damn your quick !
Not sure on how much to take it, it needs to be measured and calculated, and I don't have the formulas with me at the mo.Will probably get it reconditioned by my local chaps if I go ahead. Any ideas on how much needs skimming off ?
**Edit, found it, the fact that its unleaded might mean its either a late Cooper head (large bore and a lot of work to fit to your 998), or its had hardened valve seats put in it.
Posted 27 July 2006 - 09:07 AM
I knew you would say that ! I have the Vizard book at home somewhere so I will try and have a go.
Posted 27 July 2006 - 09:08 AM
Posted 27 July 2006 - 09:14 AM
Posted 27 July 2006 - 09:20 AM
Posted 27 July 2006 - 09:26 AM
Yes, you are looking for 12G295. With the right cam, there are better that nay modified closed chamber 998 head.
Hi Wil, sorry I didnt mention that I am trying to avoid pocketing the block if possible which I believe you have to do with a 295 casting head.
Just want a little bolt on increase for cheapo pennies whilst my 1380 is under construction
Edit, I'm thinking about a 12g940 head arent I ? the 295 is the 998 cooper head..
Edited by Jimmyarm, 27 July 2006 - 10:02 AM.
Posted 27 July 2006 - 10:19 AM
Posted 27 July 2006 - 10:25 AM
Then its back up to Slarke to see what difference it makes
Posted 27 July 2006 - 10:28 AM
Posted 27 July 2006 - 01:07 PM
Trying to figure out if its worth doing for the £££'s
Jimmy
Posted 27 July 2006 - 01:23 PM
Posted 27 July 2006 - 01:30 PM
