Bent Steering Arm
Best Answer Spider , 16 June 2015 - 09:04 PM
New Arms aren't expensive and if it is bent, it could be fatigued.
I'd suggest if replacing the Arm, to also replace the Hollow Dowels and the Bolts too. The Bolts stretch and while can feel tight can still be loose.
I have a photo I'll post up shortly of an Arm (they are on a different PC).
In the mean time, here's some measurements;-
Steering%20Arms%20MkI%20MkII_zpswixufbhl
You'd have the MKII Arms
<Edit: Here's the Photo
957-130912222331-45572492_zpseeozt98p.jp
Not mine, so I don't know it history, but it failed while the guy was driving. >
Go to the full post
11 replies to this topic
#1 plus1803
plus1803
    Just On Tickover
  • 5 posts
Posted 16 June 2015 - 10:59 AM
Hi, I've taken a steering arm off my '89. I believe it's cast iron(?) so I'm a tad concerned over simply straightening it out because of the material's properties. Will I have to purchase a new one or can it be salvaged? Cheers
#2 Carlos W
Carlos W
  • 10,115 posts
Posted 16 June 2015 - 11:20 AM
What makes you think it's bent?
#3 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 16 June 2015 - 03:54 PM
what are you calling the "steering arm"?
#4 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 16 June 2015 - 04:18 PM
plus1803: Part 14 is the above?
#5 Spitz
Spitz
  • 1,716 posts
Posted 16 June 2015 - 05:03 PM
How in the world was that bent?  I can only imagine the condition of a couple other bits if that was bent due to hitting a curb (Kerb) or such.
#6 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 16 June 2015 - 05:45 PM
Still waiting to hear if it is that part I marked or something else ...
#7 plus1803
plus1803
    Just On Tickover
  • 5 posts
Posted 16 June 2015 - 06:16 PM
Yeah I believe it is part 14? Where the trackrod end attaches to. I'm surprised it has bent and not sheered to be honest. When compared to the other side the three holes for the bolts don't seem to sit on the same axis ie. they don't all face the same way.
#8 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 16 June 2015 - 06:34 PM
I'd replace it if it is bent ... but that would indicate some poor treatment or impact damage.
#9 Swift_General
Swift_General
  • 871 posts
Not sure what you mean by holes not facing the same way. The arms are 'bent' as standard so that the inner wheel turns more than the outer to follow a tighter path - but the arms should still be a mirror image of each other. Any photos would be usedful.
#10 Carlos W
Carlos W
  • 10,115 posts
Posted 16 June 2015 - 06:44 PM
If you've managed to bend the steering arm, I'd be replacing the rack As well. The track rods would most likely bend where they go into the track rod ends long before you bend the arm
#11 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 16 June 2015 - 07:46 PM
picture paints a thousand words....
#12 Spider
  • 15,684 posts
Posted 16 June 2015 - 09:04 PM   Best Answer
Edited by Moke Spider, 16 June 2015 - 10:14 PM.
