What Type Of Sealant And Thread Lock To Use During Rebuild?
5 replies to this topic
#1 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 16 June 2015 - 06:26 PM
I was just wondering, what type of sealant for lightly smearing on gaskets and what type of thread lock should be used during rebuild? thanks
#2 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 16 June 2015 - 06:31 PM
Depends which gaskets and bolts/studs you are considering. Many ... nothing.
#3 Spider
  • 15,142 posts
Posted 16 June 2015 - 09:31 PM
I use Loctite No. 3 Gasket Goo for most gaskets, though I use an RTV Silicon of the water pump and thermostat housing. It's also the same one I use if the Diff Housing on the Gearbox is a Gasket-less type.
For thread locking, there's not many that I use this stuff on, only the Camshaft Nut, Harmonic Damper Bolt and Flywheel Bolt. I don't know the number off the top of my head, but it's the Loctite Medium Grade. I also use the same one for sealing the Freeze Plugs and if the engine has removable Oil Way Plugs.
#4 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 16 June 2015 - 09:55 PM
Mainly the clutch area and the timing chain area
#5 Minigirl
Minigirl
    With Steve
  • 1,109 posts
Posted 16 June 2015 - 09:56 PM
Thanks i will look for that stuff :-)
#6 gazza82
gazza82
  • 3,019 posts
  • Local Club: TMF+
Posted 16 June 2015 - 10:19 PM
Loctite Blue is probably the medium stuff. Red sets pretty hard and Purple for small bolts.
