Solid Subframe Mounts
4 replies to this topic
#1 nollyd
nollyd
  • 663 posts
Posted 16 June 2015 - 06:28 PM
hi all,just fitted new solid front subframe mounts all round,on driving im getting alot of vibration,i know i would get a little but are there any solutions to calm it down a bit,ie tracking etc.cheers guys
#2 nicklouse
  • 18,998 posts
Posted 16 June 2015 - 06:36 PM
You do.
Refit the rubber mounts.
Don't run big where's with low profile tyres.
#3 nollyd
nollyd
  • 663 posts
Posted 16 June 2015 - 06:50 PM
Don't run big where's with low profile tyres. ?
minis originally had solid mounts,how did they overcome this problem.i like the feel of my car now,are there any solutions besides refitting rubber.
new hi-los,cones(original),discs,pads,heavy duty tie rods.how do i go about getting it all set up properly now.
#4 Cooperman
  • 23,513 posts
Posted 16 June 2015 - 07:55 PM
The front sub-frame is ideal when it's mounted solidly. It is how the classic Mini was designed to be and part of what was such a sensation in steering feel when new.
However, that was with 10" wheels with 80-profile tyres, not the very low profile 13" tyres which fail to absorb a lot of road shocks. 13" wheels were just a styling gimmick really and were never ideal for a Mini, especially in the wet or on bumpy roads.
12" are a good compromise with 165/60 or 145/70 tyres if 10" wheels won't fit because of the 8.4" disc brakes.
You could try getting the wheels balanced again which might help.
#5 nicklouse
  • 18,998 posts
Posted 16 June 2015 - 08:02 PM
7x13s that will be harsh.
I also guess you have not had your suspension set up yet.
Rubber or poly bush mounts on your suspension!
