How Do You Get A Woodruff Key Out Of The Crank?
10 replies to this topic
#1 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 17 June 2015 - 04:33 PM
My normal method is to tap gently under one end with a thin screwdriver .. but it refuses to budge ..
Any clever tricks?
#2 nicklouse
  • 18,998 posts
Posted 17 June 2015 - 05:12 PM
Tap down on one end and then the other. It will lift out.
#3 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 17 June 2015 - 05:58 PM
Some gentle heat on the crank end can help, use an electric paint stripper rather than a blowtorch.
#4 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 17 June 2015 - 06:50 PM
nicklouse: tried that ... didn't shift and didn't hit it too hard to avoid jamming it in further. You known that feeling when you have three hammers and you wonder if you should use the smallest or largest ..  I played safe.
Tamworthbay: didn't need to try your idea ... read on ... I had stripper gun ready though.
In the end I used a nail punch ... got it underneath and tapped gently and few times and it popped up. Think the screwdriver handle was taking the shock. It was still tight to pull out though.
Now .. new one don't go back!!!! Argghhhh ........ I'll have another look to see if there is an edge or something on the crank slot before I look at whether the key needs some gentle relieving.
Cam key went in first time!!
#5 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
Posted 17 June 2015 - 06:57 PM
Heat can also work to get it back in, heat the crank and freeze the key. But it shouldn't need it, they should be tight but not that tight,
#6 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 17 June 2015 - 07:11 PM
This key seems to be a shade too wide ... it doesn't slide in .. vernier time .. :-)
#7 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 17 June 2015 - 07:17 PM
micrometer time
#8 Spider
  • 15,684 posts
Posted 17 June 2015 - 09:09 PM
Just rub the key on a Diamond Lap a few times.
#9 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 18 June 2015 - 07:10 PM
I would if I had one! I've found a micrometer though ... legacy of my late Dad ... shame he never taught me to use one (but thanks Google!)
At the moment the keys are chilling out in the freezer in the garage!
#10 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 16 September 2015 - 01:44 PM
Would one of the credit card size diamond tiles work?
#11 carbon
carbon
  • 2,590 posts
Posted 16 September 2015 - 07:00 PM
Use fine emery or wet&dry on a flat surface, such as a glass plate.
Keep the key flat on the emery and you will be able to gradually rub the sides of the woodruff key down until you can get to be a very snug fit in the crank keyway.
