mpi / spi jap mini
is there a best procedure to remove the totally inaccessible coolant temp sensor hidden under
the manifold
I can just get my left hand to it - I have small slim hands
but I cannot even get the connector off to inspect for corrosion let alone the sensor
do I have to remove the inlet manifold - will I be needing gaskets
advice much appreciated
(don't have a code reader and will also be replacing the lambda sensor shortly)
