I take it you have remembered to undo the compression tool..... ?
Removing The Front Trumpets
Best Answer Ben_O , 23 June 2015 - 08:59 PM
Go to the full post
#16
Posted 23 June 2015 - 06:57 PM
#17
Posted 23 June 2015 - 06:58 PM
By the way, be very careful doing this job - especially if you have diy'ed the tool - if it lets go then you will lose fingers potentially if your hand is in there. Don't keep your hand in there any more than is absolutely neccessary.
#18
Posted 23 June 2015 - 07:43 PM
#19
Posted 23 June 2015 - 08:18 PM
I always use "French pliers" having had one go bang as it ripped off the threads ( was a proper Churchill tool too)
FS
#20
Posted 23 June 2015 - 08:20 PM
Try twisting it around, the problem is if it's gone very flat it's larger in circumference so is difficult to get it out of the front subframe "tower"yeah have taken out the tool just the doughnut seems to big for the gap even used some lube and still wont fit out the bottom
FS
#21
Posted 23 June 2015 - 08:29 PM
#22
Posted 23 June 2015 - 08:30 PM
Have you taken out the upper arm?after half an hour of trying a crow bar and a bit of blood still dont want to budge
#23
Posted 23 June 2015 - 08:57 PM
wait whats the upper arm
#24
Posted 23 June 2015 - 08:58 PM
the bit that joins the top of the hub to the subframe that the trumpet sits in the cup on it
#26
Posted 23 June 2015 - 09:03 PM
#27
Posted 23 June 2015 - 09:25 PM
FS
#28
Posted 23 June 2015 - 09:37 PM
Old cone is fat & doesn't want to go. I managed it after removing the top arm & turning the cone on its side.
As before, wiggle. Or get a lever in therel
#29
Posted 23 June 2015 - 09:42 PM
right will remove the arm tomorrow cheers for help guys hopefully new doughnuts turn up and can start rebuilding then
#30
Posted 25 June 2015 - 03:54 PM
