Fan Catching Timing Breather
Posted 22 June 2015 - 07:23 PM
Posted 22 June 2015 - 07:28 PM
Posted 22 June 2015 - 09:49 PM
As I recall, 998's use one standard spacer, 1275's use two. My '92 1275 cooper SPi has 2. The extra one is to clear the breather.
Edited by spiguy, 22 June 2015 - 09:49 PM.
Posted 22 June 2015 - 10:07 PM
There were many combinations of spacers, radiator cowlings and the bottom brackets to achieve all the clearances needed not only from the Oil Separator but also from the Harmonic Damper and also the body cowling (when they fitted them).
Posted 22 June 2015 - 10:26 PM
Or as we often did a pile of washers on each bolt as needed.
Posted 22 June 2015 - 10:31 PM
Just one other thing before fitting spacers etc, more so if the fan is a metal blader, but even if plastic, check that the fan is still flat.
Edited by Moke Spider, 22 June 2015 - 10:32 PM.
Posted 23 June 2015 - 01:38 AM
Does the breather have a flat side? If it has a totally cylindrical separator it'll catch as it's for a Metro etc. with no fan to catch.
Posted 23 June 2015 - 06:15 AM
Edited by danny19boy86, 23 June 2015 - 06:16 AM.
Posted 23 June 2015 - 06:24 AM
http://www.minispare...I.aspx?2~12~113
Also ensure fan is on the right way round
Posted 23 June 2015 - 07:41 AM
Edited by Mini Manannán, 23 June 2015 - 07:43 AM.
