Humming Noise
Posted 23 June 2015 - 10:41 AM
Hope you can shed some light on what I could be. Thanks
Posted 23 June 2015 - 12:29 PM
Sounds like it could be a noisy clutch release bearing
Posted 23 June 2015 - 12:57 PM
Need more info really. Where does it seem to come from? Humming is a hard one to imagine, is it high or low frequency? Sure it isn't just something vibrating?
Posted 23 June 2015 - 05:36 PM
Posted 24 June 2015 - 11:29 AM
Could it be pressure building in the radiator?
Posted 25 June 2015 - 07:36 AM
If its the fan side of the engine, could well be the water pump is showing signs its on the way out.
Posted 27 June 2015 - 08:23 AM
I changed the water pump and radiator about 6 months back.
Posted 27 June 2015 - 08:33 AM
Don't disregard failure of new components. Agreed its less likely, but there seems to be a lot of cheaply made components around. We have had several failures in newly fitted items (cylinder head gasket, amongst others) and been very confused until testing the new part - to find its failed already.
Posted 27 June 2015 - 02:27 PM
Suggest removing fan belt to isolate water pump and alternator. Does noise appear regardless of engine temperature? Agree with Nick, if noise disappears when you depress clutch, best guess is clutch release bearing
Posted 30 June 2015 - 09:03 AM
Yeah I suppose it could be a faulty new part, the noise is when the temperature is just below the halfway mark and the noise goes away when you engage the clutch, sat in neutral is when I can hear the noise. thanks for all your help really appreciate it
