Compression Ratio - D Top Pistons
6 replies to this topic
#1 Wright&Wright
Wright&Wright
  • 309 posts
  • Local Club: Central Mini Owners Club
Posted 24 June 2015 - 09:13 PM
Does anyone know what kind of maximum compression ratio is suitable for the Cooper D top pistons?
I'm rebuilding the 998 engine for around 60bhp on a +20 thou overbore. The head is a 295 and hasn't been skimmed but did does appear to have an appropriate amount of port work done.
I want to run around 10.5:1 comp ratio but I'm not sure whether the original pistons will be good in coping with this? Any help would be appreciated.
#2 Carlos W
Carlos W
  • 10,115 posts
Posted 24 June 2015 - 09:14 PM
If the engine is apart, I'd measure the compression ratio
#3 blacktulip
blacktulip
  • 6,231 posts
Posted 24 June 2015 - 10:20 PM
What cam are you using?
#4 Spider
  • 15,684 posts
Posted 25 June 2015 - 01:04 AM
Just to be clear - you'd like to know if the original Raised 'D" Cooper Pistons are OK with a CR of 10.5:1?
Yes, my wordy.
In fact they'd be OK right up to about 14:1.
#5 grck1
grck1
  • 198 posts
Posted 25 June 2015 - 10:14 AM
can you still buy 998cc d top pistons?
#6 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 25 June 2015 - 10:50 AM
Try F W Thornton's ... they hold new old stock of a lot of engine parts (and knew that before they were on Car SOS with the Austin 12!)
#7 Wright&Wright
Wright&Wright
  • 309 posts
Posted 25 June 2015 - 12:15 PM
I'll most definitely be measuring the comp ratio before the build is finished but thanks for the advice.
The cam is a 266.
