Ok here we go. MKI Mini running Negative earth with points & dynamo.
Just rebuilt & all works fine, except the ignition light stays on!. It will dim slightly when increasing the revs but is still on.
Dynamo produces good readings & all through the charging system.
I have even tried another good & known working Dynamo & regulator box, but it produces near enough the same readings.
Warning bulb holder & wiring is fine.
I do have an in line smiths tacho which has ironically stopped working now. Although the problem still exists when I take this out of the loop.
I have changed the ignition switch from last time & just wondering if this could feed it (wiring is the same though).
Anyone come across this problem?.
