Wobbly Pistons
14 replies to this topic
#1 shinyer
shinyer
  • 20 posts
Posted 01 July 2015 - 09:33 AM
I had my head off to replace stems seals as I had quite abit of smoke on start up, so at the same time I gave the top of the Pistons a clean up but whilst doing so I noticed a slight movement of the Pistons from side to side. Is this normal? Or are the stem seals the least of my problems? It's a 1275 a+ and it's apparently had a recent rebuild according to the person who supplied it.
#2 MINIMADrt
MINIMADrt
  • 465 posts
  • Local Club: none at mo
Posted 01 July 2015 - 09:34 AM
How much movement. You would expect slight movement on any engine. But depends on how much we are talking.
#3 shinyer
shinyer
  • 20 posts
Posted 01 July 2015 - 09:41 AM
Probably give or take 12-15 thou
#4 Spider
  • 15,160 posts
Posted 01 July 2015 - 09:49 AM
It's probably fair to say that it's not at all easy to say if there's a problem or not. They may have some movement and that could be normal. Pistons do expand when under normal use (from heat mostly) and they will expand the most where there is the most heat and material in the piston, so the Crown, which is what you can see with the Head removed, will expand the most. The Pistons are shaped (said to be Cam Ground) to allow for expansion of it's irregular shape. Typically, when cold, most 'movement' will tend to be along the same line as the Crank.
While the Piston to Bore Clearance is 'fine' (typically in the range of 0.0015 to 0.004") on these Engines, it's normally measured at the lower end of the Piston Skirt at 900 to the Crank Line
#5 MINIMADrt
MINIMADrt
  • 465 posts
Posted 01 July 2015 - 09:52 AM
I take it you will be changing the oil one trick you can do if so is put all Pistons half way down they are not liners so should be ok and will each one with petrol if one drops or two ect ect then rings could be at fault but make sure same amount is in each and leave for some time make sure to change the oil after
#6 shinyer
shinyer
  • 20 posts
Posted 01 July 2015 - 10:02 AM
Thanks guys, I think more investigation is needed before I jump to any conclusions
#7 MINIMADrt
MINIMADrt
  • 465 posts
Posted 01 July 2015 - 10:05 AM
Yep. I would do as much. Investigating as pos before you start ripping it apart.
#8 MINIMADrt
MINIMADrt
  • 465 posts
Posted 01 July 2015 - 10:09 AM
Does sound to be fine but better safe than sorry
#9 jaydee
jaydee
  • 8,565 posts
Posted 01 July 2015 - 01:52 PM
You dont want 12 thou movement, they have to be firm.
Investigate further.
#10 shinyer
shinyer
  • 20 posts
Posted 01 July 2015 - 03:20 PM
Would a compression test show me if there was a problem?
#11 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,080 posts
  • Name: Neil
Posted 01 July 2015 - 03:24 PM
It may point to worn rings so worth doing a leak down test.
#12 MINIMADrt
MINIMADrt
  • 465 posts
Posted 01 July 2015 - 03:51 PM
If you have access to one a cylinder leak back test would be perfect. Tdc screw in to spark plug hole load up with about 10-15 psi and then listen to the exhaust. Oil filler dipstick hole and air filter housing. If you can hear air coming from either then that's the indication you need to pin point it down. Also has a gauage on to Keep an eye on pressure to see if it's dropping of or not.
#13 carbon
carbon
  • 2,590 posts
Posted 02 July 2015 - 05:01 PM
You will find a lot more clearance at the top of the piston, and it will rock quite a bit when cold, needs to be this way to allow for expansion.
I wouldn't worry about this, but do check the bores for any sign of a lip. Looking down the side of the piston you should be able to just make out the ring gaps, these gaps should looks similar for all 4 bores.
For the valve stem seals are you fitting them on both inlet and exhaust?
#14 shinyer
shinyer
  • 20 posts
Posted 03 July 2015 - 08:18 PM
Yes will be fitting stem seals to both valves, I'm tempted to just go the whole hog and replace valves and guides as they do seem very loose.
#15 Cooperman
  • 23,327 posts
Posted 03 July 2015 - 10:35 PM
Pistons MUST have some free-play or else they would seize up when the engine got hot. it's the rings which control the compression.
Machine shops bore the engine to suit the piston skirt to bore at the bottom of the piston, not the top.
However, if the engine has been newly & incorrectly bored the pistons can 'rock'' in the bores and this causes a 'ripple' finish on the bores and scores the piston skirts which will show as excessive oil consumption and lots of 'blow-by'. Unless this is happening on a new-build engine there should be nothing to worry about.
