Hi all - I've got a late 70's Mini 1000, and I've recently started having some issues shifting.
I changed my oil, and went for a drive. Shifting 1-2 and 3-4 were smoother than ever. 2-3, not so much! Here's a video I took of what happens. The behavior is the same with the clutch in or clutch out.
It feels like it's getting hung up, almost like the teeth weren't meshing quite right. I thought maybe it was an issue with the oil (AMSOIL Z-Rod 20W50), so I chose a different one (Valvoline VR-1 20W50) and changed it again. The issue continued with the new oil, so I went poking around a bit. Must have been a coincidence that it surfaced during the oil change.
I took off the shift boot and noted that there was a lot of motion in the gear lever assembly.
Video 1:
Video 2:
I'm guessing that's not a normal amount of play.
Next, I got under the car and started tinkering with the linkages. The lower bar is exceptionally loose, and the front roll pin is either very worn, or completely missing!
(Excuse my accent )
My next steps are to see what the mounting hardware for the gear lever looks like (if it's loose), and to see how I can patch up the shift linkage and the roll pins. Since I know at minimum the roll pin needs to be done, I have a few other remaining questions....
- How can I tighten up the movement of the gear lever itself on the assembly? As far as I can tell, there's no hardware to secure the retainer cup to the top of the gear lever assembly, and it's quite loose. What are the chances this indicates a problem with the gear lever assembly?
- Can I remove the gear lever assembly (with the linkages) easily? I haven't flipped through my Haynes manual yet, but should I be able to get the whole thing out if I just unbolt the box and take out the fixing pins near the front?
- Any other parts I should be replacing at the same time? I'm looking into the gear bias barrel, but I'm also considering a quick shifter. Any thoughts on those?
Thanks for any advice you can offer!
