Hi
I am going to look at a mini clubman gt 1980 and just wanted any advice it will be very appreciated.
Also what colour should the engine bay be? Any info, tip and spec is great.
Many thanks in advance Elliot
Posted 02 July 2015 - 05:53 PM
Hi
Posted 02 July 2015 - 06:19 PM
The engine bay should be the same colour as the body work unless you mean the Engine?
Posted 02 July 2015 - 06:36 PM
check engine number 12H706
and
body number XE2D2
Posted 02 July 2015 - 06:51 PM
Posted 02 July 2015 - 07:59 PM
thanks
Edited by wayheyell, 02 July 2015 - 10:55 PM.
Posted 02 July 2015 - 08:18 PM
Putting a vin mumber on a public forum is not a good idea. I will hide parts of it.
Posted 02 July 2015 - 11:01 PM
is a gt clubman mini suppose to be twin su carbs?
Posted 02 July 2015 - 11:15 PM
Take a magnet to check for filler/rot.
Good idea but make sure you ask permission from the seller first though and if necessary put something between the magnet and the paintwork.
I wouldn't want someone potentially scratching my car checking for filler.
Posted 02 July 2015 - 11:39 PM
No, not as standard.is a gt clubman mini suppose to be twin su carbs?
Posted 03 July 2015 - 05:12 AM
The UK built ones were only single 1-1/2" (HS4) SU, as mininuts has pointed out, however the Aust Built Clubman GT did have twin 1-1/4" (HS2) SUs, as per MKII Cooper S as standard.
Posted 03 July 2015 - 08:33 AM
Also should it be on hydrolastic sus? Thanks
Posted 03 July 2015 - 08:54 AM
A 1980 model? - No. Hydro was phased out in 1971, however I don't think the UK Clubman range was ever fitted with Hydrolastic.
<Edit: Yes, hydro was fitted to the early GTs but the last car fitted with it was S20D-8155A. All Aust GT production had it fitted to the end of GT production (December 1972). >
Edited by Moke Spider, 03 July 2015 - 09:00 AM.
Posted 03 July 2015 - 09:11 AM
Thank you for this info its really helpful!
