oil filter pipe
blacktulip
, Jul 28 2006 05:02 PM
8 replies to this topic
Posted 28 July 2006 - 05:02 PM
is there a seal for the oil filter pipe that connects to the block under the coil? the engine in question is from an mg metro. if not what could i do to stop it leaking?
Posted 28 July 2006 - 05:05 PM
should have two copper washers, one between the banjo bolt and the pipe and another between the pipe and the block...
Easy way to get them is to buy an engine gasket kit..
Posted 28 July 2006 - 05:26 PM
cheers bud! would it be a straight forward job ie. just un bolt, put them on and do up again?
Edited by mikecmini, 28 July 2006 - 05:28 PM.
Posted 28 July 2006 - 06:24 PM
Yup......need to loosen the other end as well so you can swing it away to get the inner washer in.
Have a rag ready as well to catch the small amount of oil that will leak out.
Posted 28 July 2006 - 08:30 PM
I had one of these that pushed in had the daft rubber seals that came on the early SPi engines. I replaced the seals four times and in the end gave up and changed the pipe for a steel braided one with new banjo bolts and copper washers.
I think I got it from MiniSpares but it was 13 years ago. (Blimey, now I feel old, lol.)
Tony
Tony
Posted 29 July 2006 - 09:44 AM
An MG Metro doesn't have an olive sealed pipe.
The copper washers for the banjo are the same as the sump plug washer, should be able to get some at Halfords as Mini sump plug washers.
You don't need to slacken the oil filter end, the pipe will flex enough to slip the old washer out and the new one in. It is a good idea to clean the mating faces well though, in which case you should slacken off the lower fitting.
They leak because they harden and then if you disturb the flow pipe for any reaon they don't seal up well again. You could try to re-anneal the washers you have but for the price of a couple of new ones it's not really worth it.
Edited by Dan, 29 July 2006 - 09:45 AM.
Posted 29 July 2006 - 11:47 AM
do u think using some plumbers jet blue plus would be ok for adding a paste type sealant between the washers or does it need to be a dry seal?
Posted 29 July 2006 - 11:58 AM
Don't use any sealant, you don't need to. If you do then some of it will get through into the oil filter and block it up really well. Even worse it could well get trough the filter if it hits the bypass valve and into the engine. Annealed copper washers seal perfectly if they aren't hardened.
Posted 29 July 2006 - 05:12 PM
ive got the washers now, just cant undo the damn nut lol. gonna have to buy a long breaker bar.
