[1979 Mini 850] Fuel Gauge Not Reading Correct.
1 reply to this topic
#1 Chesterman
Chesterman
  • 25 posts
Posted 04 July 2015 - 10:35 PM
Since I've had my mini the fuel gauge doesn't read correctly. When I fill my tank it shows up between 1/2 and 3/4 full and then sits on empty for quite a while before actually being low on fuel. Is this just a new tank sensor or could it be something else?
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 04 July 2015 - 11:45 PM
Could be the float is split and its got some fuel inside, whip the sender out when the tanks below the mark and check it, if its ok work it over the full range to see if the track is damaged.
