I am just looking for some advice on the removal of underseal, the underseal is the thick tar like stuff and I cant get it off, if I use a grinding wheel the stuff just heats up and spreads then dries again, if I use sand paper it just clogs it all up and doesn't remove it, if I heat it up it just bubbles then dries soft again, if I try to heat it and scrape it comes of a little bit but still leaves lots of it on the metal! its awful stuff! I have no idea what it is, any ideas would be much appreciated!
Underseal Removal
Posted 05 July 2015 - 10:06 AM
Posted 05 July 2015 - 11:25 AM
Posted 05 July 2015 - 11:38 AM
Probably heat and scrape followed by a twisted wire cup in a grinder. Horrible long winded job, dont envy you at all
Cheers for the advice, i will nip to toolstation and go and get some wire cups, not looking forward to this! Haha
Posted 05 July 2015 - 12:08 PM
There is no quick way to remove it.
Soften scrape, soften scrape and repeat. The residue can be removed with thinners.
Awful messy job
Posted 05 July 2015 - 01:12 PM
All of the metal rusts underneath anyway with it on!
Edited by kyle9832, 05 July 2015 - 01:13 PM.
Posted 05 July 2015 - 03:22 PM
It's bitumen based i think?
I have applied it in the past and it's thick like tar and gets everywhere.
I was mis-advised and only 14 at the time so i didn't know any better. I'd never use it again
Posted 05 July 2015 - 03:26 PM
Edited by kyle9832, 05 July 2015 - 03:26 PM.
Posted 05 July 2015 - 04:38 PM
get some solvent based paint stripper, not nitromors, and hammer it with it and let it dry. do that a couple of times and you will be able to flake the majority of it off in one go.
Posted 05 July 2015 - 05:07 PM
thanks for that, think i may have to go down that road because it took me 6 hours just to do half a front subframe! the underneath is going to kill me at this rate haha!
