Diagonal Split Or Front/rear Brake System
7 replies to this topic
#1 wouterke
wouterke
  • 25 posts
  • Local Club: Mini Fun Club Belgium
Posted 09 July 2015 - 07:04 AM
Hi,
My mini now has a diagonal split brake system.
But I'm putting all my brakes/engine from my other mini which has a front/rear brake system.
Shall I change it to front/rear brake system?
What do you guys think is the best?
New setup has 7,5" brake discs in the front, and drums in back.
I would prefer front/rear, because I know these works.
I think both have there pros and cons?
I would like to hear your opinion.
p.s.: I will be pulling an Eriba puck later on with it.
#2 Spider
  • 15,254 posts
Posted 09 July 2015 - 08:09 AM
If there's no MOT issue, then I'd suggest Front / Rear split is better.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 09 July 2015 - 01:43 PM
+1 Front and rear
#4 wouterke
wouterke
  • 25 posts
Posted 10 July 2015 - 09:22 AM
Just as I was thinking.
I also prefer the front/ rear setup.
Thanks folks ;)
#5 minimanclive
minimanclive
  • 1,108 posts
  • Local Club: LSMOC
Posted 11 July 2015 - 08:07 PM
My clubman estate had the diagonal split circuit brakes. When I fitted front discs I converted it to front rear split. The factory only fitted diagonal split for a less than a year before changing to front / rear split.
#6 minisprint
minisprint
  • 1,036 posts
  • Local Club: GR8 minis
Posted 11 July 2015 - 09:49 PM
My mini van has single line . Single leading shoe and pulls and stops my eriba puck.
#7 Ethel
  • 26,187 posts
Posted 11 July 2015 - 10:00 PM
Can't link of any pros for diagonal, a Mini with one front brake is almost as bad as no brakes.
#8 Spider
  • 15,254 posts
Posted 12 July 2015 - 12:36 AM
Maybe it's just me, but I tend to think them worse. They tend to want to steer - quite heavily - when under brakes towards the one working brake.
So while you may not smash in to the guy in front, you'll take out the guy beside you.
