Sticky Accelerator
10 replies to this topic
#1 postma
postma
  • 41 posts
Posted 10 July 2015 - 04:44 PM
My 1275 of 1992 have had a new accelerator cable, but the pedal movement is still sticky.
I've checked the trottle movement with the cable attachedto the carburettor but not the pedal and everything goes smooth.
Checked the bronze bushing in the firewall (where the cable goes in) and that is OK.
The spot where the cable comes out of the firewall and going to the pedal is perfectly in-line, but once attached to the pedal it does not move smooth.
I'm lost and see no other obstructions, but it's verry anoying, once you want to accelerate it goes with a jump.
Anyone having a solution?
Thanks,
#2 Stu.
Stu.
  • 912 posts
Posted 10 July 2015 - 06:01 PM
Have you checked the pedal movement without the cable attached?
#3 robminibcy
robminibcy
  • 1,516 posts
Posted 10 July 2015 - 06:13 PM
I've found that this can happen if the cable outertubing is not routed on to the carb properly. Have a quick look on google images for pics of how the cable runs on to the carb and that yours is the same.
#4 postma
postma
  • 41 posts
Posted 11 July 2015 - 07:00 AM
Pedal mouvement is OK without attachement.
#5 Stu.
Stu.
  • 912 posts
Posted 11 July 2015 - 07:05 AM
You could try taking out the cable and spraying some wd40 down the outer. Maybe the cables fouling as it moves inside the outer and only happens when its all connected.
#6 postma
postma
  • 41 posts
Posted 11 July 2015 - 07:09 AM
I've tried different routings, but no changes, currently it's routed in the best possible way , but still sticky.
I'm puzzled ......
#7 postma
postma
  • 41 posts
Posted 11 July 2015 - 09:52 AM
Today took the new accelerator cable out, greased the inner cable, put it back and everything moves smoothly.
Attached one end to the hif38 carburettor (the throttle moves freely) and pulled the inner cable from the other end,   is OK
checked the pedal movement, no problem there and the spot where the inner cable comes out the firewall hole and meets the pedal is spot on lined-up.
Once the cable is attached to the pedal, it is still a bit sticky, especially from zero to mid position of the pedal.
Are there no alternatives........?
#8 Ethel
  • 26,018 posts
Posted 11 July 2015 - 03:09 PM
The pivots on the pedal are very crude and can catch through wear. The other classic, is the cable standing in for broken earth straps and arc welding itself to the outer. DSN do a well posey alloy pedal that'll empty yer piggy bank.
#9 postma
postma
  • 41 posts
Posted 11 July 2015 - 04:10 PM
Like I wrote, the pedal (Pivot) itself moves freely and was given a bit of oil again.
The whole car is coming out of a total restoration, so there is a new earth strap fitted.
#10 Dusky
Dusky
  • 5,322 posts
Posted 11 July 2015 - 06:00 PM
I Had the same problem. Show US a pic of how the throttle cable is connected on yours, it needs to go under the cam to prevent caching, hope this solve it
#11 ADDvanced
ADDvanced
  • 14 posts
Posted 15 July 2015 - 05:29 AM
What do you mean by under the cam?
