Strange one this, I've removed the water pump and radiator to replace the bypass hose. Decided to clean and degrease the block and head while everything was out the way and I found what looks like a pop rivet fitted in the head behind the bypass hose.
As there's a hole there, does anyone know what should be there (if anything) as clearly a rivet should not. Guessing drilling it out would be the best way to remove it?
