Oil Pressure
Posted 11 July 2015 - 08:12 PM
Posted 11 July 2015 - 08:41 PM
An Oil Light will do fine.
Remover all the spark plugs and turn the engine over on the starter until you get Oil Pressure.
You may find it helpful to remove the Banjo Bolt, on the Oil Feed to the Oil Filter, just up and to the left of the Dissy, fill the drilling in the block with engine oil (Oil can is helpful here) and replace the Banjo bolt, being sure the 2 copper washers (one each side of the banjo) are still in place. This will prime the oil pump.
It usually only takes around 30 seconds after priming to get Oil Pressure up, but it can take several minutes of cranking, so be patient. Do not start it until you are 100% sure you have Oil Pressure.
Posted 11 July 2015 - 09:56 PM
It'd be well worth fitting a gauge, comparing the cost to what you've likely already spent.
There are also differently rated oil switches, the original is better at telling you your engine is already knackered
than warning: the pressure might be in single figure before it lights. It'll still do as Spider suggests for a new engine
Posted 11 July 2015 - 10:23 PM
Let use know how it goes
Posted 15 July 2015 - 04:14 PM
I've read that by filling through the block and turning the engine backwards you can fill the oil pump ... not sure if anyone has tried that or would agree this is a good way ??
Posted 15 July 2015 - 06:13 PM
to effectively prime the oil pump you will need to remove the banjo at the block as described above with the plugs out and engine not running put the car into second gear and push the car backwards or jack the car up and turn the front wheels backwards this will draw the oil into the oil pump as you pour fresh oil into the hole. Once you have sufficient oil in the pump re-connect the banjo and spin the engine over with the starter, after 20-30 seconds you should have oil pressure and the oil pressure light should go out.
Posted 15 July 2015 - 07:26 PM
Posted 15 July 2015 - 08:33 PM
A new oil filter MUST always be filled with fresh oil when being fitted.
Edited by Cooperman, 15 July 2015 - 08:33 PM.
