Refitting Flywheel To Spi
Posted 13 July 2015 - 05:09 AM
Posted 13 July 2015 - 06:36 AM
They only fit in one place correctly.. The keyway across the end of the crank is offset as is the corresponding keyway in the flywheel/clutch, make sure this is correctly lined up and you will not have a bother with the timing.
Also if you're changing the clutch, make sure you get one which is specifically for the injection and not just a standard one as this WILL mess up your timing.
Posted 13 July 2015 - 06:42 AM
Aha! Hoped that was the case. Thanks for the heads-up on clutch.
Posted 25 October 2015 - 07:48 PM
Just put the flywheel & clutch in the car, and it fits both ways round! The keyed washer is symmetrical... But I talked to someone who knows injection systems and he said that the crank position will indicate rotation and rpm, and the dizzy sorts out the ignition. Or did I miss something here? I didn't torque the flywheel on in case... and there's nothing in Haynes that helps with one way round or not.
Posted 25 October 2015 - 07:56 PM
The keyway is NOT symmetrical, however, with the engine in the car it can be difficult to tell.... Use a Mirror so you can see the crank end on.
If you put the clutch/flywheel on 180 degrees out then it'll not start
Edited by Guess-Works.com, 25 October 2015 - 07:58 PM.
Posted 25 October 2015 - 08:38 PM
Posted 26 October 2015 - 03:59 PM
When refitting, should the wheel be lapped onto the crank as good practice?
Posted 26 October 2015 - 04:04 PM
Ideally, yes, but with the engine in the car you need to be very careful to lap the whole taper and not just run the flywheel round while it's weight is supported on the top of the crank..
Posted 26 October 2015 - 08:39 PM
Very good point. Did mine out of the car. Maybe one could lap a bit, rotate crank, lap some more... Or, just pull the motor and do it right:-)
Posted 27 October 2015 - 12:27 AM
I did that too. I also put some WD40 on the taper and the wiped it off to reduce the friction when installing the flywheel. I also put some WD40 on the centre bolt threads.
Edited by xrocketengineer, 27 October 2015 - 12:31 AM.
Posted 31 October 2015 - 11:28 PM
My Rover dealer did this!! What a story, too long for here, unbelievable.
Posted 22 November 2015 - 05:46 PM
With some embarrasement about the delay, I followed your advice. Although no mention in Haynes, there is indeed a difference. Naturally, has the flywheel 180 degrees out, so pulled off & reset. The taper is so clean the flywheel had set itself on the crank, so out with the puller... Looks good so far!
