Posted 14 July 2015 - 01:28 PM
Posted 14 July 2015 - 02:10 PM
Posted 14 July 2015 - 03:03 PM
The drive for an A series engine is different to an A+ and will not fit in an A+ motor
Depending upon the type of dizzy you have purchased, 25D or 45D you can swap the internals of an A series dizzy into an A+ dizzy therefore making an A+ version, but a better alternative is to just buy an A+ dizzy.
If you bought it new I would contact the company you bought it off, they may swap it for an A+ and if your lucky may cost nothing or only a restock fee.
Posted 14 July 2015 - 04:03 PM
Posted 14 July 2015 - 05:43 PM
Posted 14 July 2015 - 09:45 PM
You can swap the Drive Dogs on the Dissys over.
I do recall looking at machining up an A Drive to fit in to an A+ Block and I seem to recall the A Drive is just simply too short to do the job.
Posted 15 July 2015 - 06:09 PM
Il just get the right dizzy, i spoke to minisport and they said your best getting the right dizzy, cheers for the replies lads!
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Yellow Tag Brake Master Cylinder QuestionsStarted by John K Series , 12 Mar 2026 |
Time To Bleed The BrakesStarted by Murrayup , 11 Mar 2026 |
Clutch And Fan Noise From Newly Rebuilt 1380 Engine.Started by sam138 , 19 Feb 2026 |
1968 Cooper Parts NeededStarted by Neilmr , 14 Feb 2026 |
New Rear Drums Locking/bitingStarted by SteadyEddie , 11 Feb 2026 |
