How do they go on? The shaft is out and the outer boot off but which way does the "small clip" section of the boot go? does it stay inside out / inverted and the clip goes on the inside so only the big clip is visible that connects to the pot joint / diff input part or do you make it sit like how the outer boot is and "unfold" the boot.
Just confused as one was done one way and the other done the other way when I removed them!
thanks
