81" Van - Mot Requirements
10 replies to this topic
#1 SAL 821X
SAL 821X
  • 1,890 posts
Posted 15 July 2015 - 03:20 PM
Does anyone have an idea of what the MOT requirements are for a 1981 Van.
Mainly does it need fog & Reversing lamps?
That useless light for checking the brake pedal on the dash?
Hazard warming light switch?
#2 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 15 July 2015 - 03:25 PM
I'm not sure if you need a hazard light switch but i would defiantly want one regardless of the age and requirement. If you break down at night on a quiet road, nobody is going to see you.
#3 SAL 821X
SAL 821X
  • 1,890 posts
Posted 15 July 2015 - 03:38 PM
Valid point Ben I just want to keep the switches on the dash to a minimum.
#4 sledgehammer
sledgehammer
  • 3,129 posts
Posted 15 July 2015 - 03:51 PM
http://www.motuk.co.uk/manual_140.htm
Hazard warning devices are not required on vehicles first used before 1 April 1986, but if one is fitted it must be tested.
reverse lights are not required or tested for MOT
I'm sure the brake fluid level light & test switch is a requirement if fitted - but can't find the date that started
section g - http://www.motuk.co.uk/manual_360.htm
Edited by sledgehammer, 15 July 2015 - 03:59 PM.
#5 SAL 821X
SAL 821X
  • 1,890 posts
Posted 15 July 2015 - 07:56 PM
So if it's not fitted it's not required then ;)
#6 sledgehammer
sledgehammer
  • 3,129 posts
Posted 15 July 2015 - 10:02 PM
According to the testers manual
as long as the car is registered before 1 April 1986
I thought they were required from the 70's , as a lot of cars had them way before 1986
#7 MrBounce
MrBounce
  • 2,685 posts
Posted 16 July 2015 - 05:25 AM
A rear fog light is definitely needed as these cwere a requirement from 1980.
#8 SAL 821X
SAL 821X
  • 1,890 posts
Posted 16 July 2015 - 05:52 AM
Fog light it is then.
#9 SAL 821X
SAL 821X
  • 1,890 posts
Posted 16 July 2015 - 07:59 AM
So by that then I need 3 switches for the dash the hazards, headlights, fog light and a reversing lamp on the valance.
#10 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 16 July 2015 - 12:01 PM
Your rod change should have a switch for the reversing light
#11 SAL 821X
SAL 821X
  • 1,890 posts
Posted 16 July 2015 - 08:02 PM
Sorry meant fog lamp not reversing lamp.
