Rattling From Engine Bay
10 replies to this topic
#1 MaxDempsey
MaxDempsey
  • 136 posts
Posted 15 July 2015 - 05:02 PM
Hi
My 1989 Mayfair has developed a slight rattle from around the radiator area. The car is a 988cc. Could this be the alternator or maybe even the water pump or is it just a case a replacing parts until the rattle stops.
The rattle also seems to stop as the revs increase although I'm not sure whether this is due to the noise increase from the engine.
Thanks in advance.
#2 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 15 July 2015 - 08:34 PM
You need to pin the sound down so get a length of plastic pipe 18 inches long, put to your ear and 'localise' the sound, you'll then have a better idea than "around the radiator area".  If you're feeling posh get one of these: http://shop.aseriess...thoscope-320mm/
#3 MaxDempsey
MaxDempsey
  • 136 posts
Posted 15 July 2015 - 09:13 PM
Ill try that and maybe even stretch my funds to buy a stethoscope  :D
#4 peter-b
peter-b
  • 773 posts
  • Local Club: still looking
Posted 15 July 2015 - 09:18 PM
If you're a bit handy, try taking the fan belt off and see if noise is gone. Don't run it for too long obviously, a few minutes should be sufficient. If the noise is gone, try then spinning fan and alternator to see if you can hear anything or feel harshness in bearings. If the noise doesn't stop with belt off, you should be able to assume the pump/fan and alternator are OK.
As MM said, a bit better description as to type of rattle and area would be good. Is is tinny rattle, solid rattle, try CAREFULLY pushing around fan cowl read area, alt etc. Might just be loose item.
#5 MaxDempsey
MaxDempsey
  • 136 posts
Posted 15 July 2015 - 09:25 PM
Thanks for the advice and dealing with my vagueness  ;D I will try taking the belt off tomorrow if the plastic pipe idea doesn't work.
#6 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 15 July 2015 - 11:36 PM
timing chain all day long
#7 Broomer
Broomer
  • 1,771 posts
Posted 16 July 2015 - 07:39 AM
I thought if an A series wasn't rattling something was wrong ?
#8 MaxDempsey
MaxDempsey
  • 136 posts
Posted 16 July 2015 - 08:57 AM
Seems that way  :lol:  Can you get to the timing belt by taking the rad out or is it an engine out job
#9 peter-b
peter-b
  • 773 posts
Posted 16 July 2015 - 09:37 AM
They don't rattle when they're not running, nothing wrong there. :-)
#10 ChopperHarris
ChopperHarris
  • 1,139 posts
Posted 16 July 2015 - 03:37 PM
Yes you can get to the CHAIN in situ
#11 MaxDempsey
MaxDempsey
  • 136 posts
Posted 16 July 2015 - 06:36 PM
Thanks, didn't notice I had written belt  >_<
