Indicator Flasher Unit
4 replies to this topic
#1 eilz1999
eilz1999
  • 68 posts
Posted 15 July 2015 - 08:53 PM
I have a 1979/80 mini 998. My hazard lights are flashing normally but my indicator lights are just constantly on (working but not flashing) when in use. I think the flasher unit is faulty. I think Both of mine are in the engine bay (by the screenwash bottle). See photo. I think the one in my hand is the faulty indicator flasher and the lucas behind is the hazard flasher. Am i correct? What is the part number for indicator flasher? Any help will be much appreciated.
#2 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Posted 15 July 2015 - 08:59 PM
I would pull it off and give the connections a good clean, looks a bit crusty.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 July 2015 - 09:33 PM
Indicator Flasher is 2x21w Hazard is 4x21w
#4 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 16 July 2015 - 12:31 PM
When in doubt, turn the hazard lights on (since you say they are working) and put your finger on each of the two flasher units.  You will be able to feel mechanical ticking from the flasher used for the hazard lights.
#5 Wise Old Elf
Wise Old Elf
  • 1,655 posts
  • Local Club: Club Lotus
Posted 16 July 2015 - 04:44 PM
I swapped mine for electronic units and the flash is much more constant.
I bought square ones from China as I am a cheapskate but the ones below look good.
http://www.ebay.co.u...=item27eacbbb66
