Hi all,
Purchased a 95 model SPi last year, the heater did not work when I bought the car but not having owned a mini for over 20 years I was not sure what the problem was. Any a leaking rad ended up in not only replacing the radiator with an all alloy affair but the heater cable was replaced, the heater outlet pipes as these where completely blocked up bit basically decintigrated upon removal, the matrix was replaced it was looking worst for where and judging by the date stamp was probably the original. Anyways I hosed the system out when everything was apart,I've now replaced everything including waterpump and one of the heater pipes leading to the in-line valve, I tried filling the cooling system, the system gets hot one side of the heater valve but not the other and there is no heat in the cabin? I have left the heater pulled out so that it open when I fill the system and tried running the car with the rad cap off to allow any trapped air to escape but still no joy. I've drained the system twice now.
I assembled everthing back as it came off so I'm assuming it was correct in the first place, this may be a daft question but when connecting the inlet/outlet pipes back upto the heater matrix does it matter which way the pipes go? I've attached a photo, the pipe nearest in the photo marked 'w=car heater hose' is a new pipe which is connected to the in-line valve, the pipe behind is the original moulded pipe which I assume is the outlet. Would this set up be correct or does it not matter?
Any other thoughts/suggest most welcome, thanks.
INLETDSC_1138.JPG 49.75K
8 downloads
