Is anything meant to be used to attach the plastic strip that goes between the "special" wheel arches - http://www.minispare...ic/CZH4316.aspx - ?? I got mine back from the bodyshop a couple of months ago and they're both pretty loose just pushed on - so much so I've actually taken one side off for fear of it coming off while I'm driving - and the other side isn't much better. Did they really just push on? Any advice on what I could use to secure them?
Attaching Plastic Strip Between "special" Arches.
Posted 22 July 2015 - 08:54 PM
Posted 23 July 2015 - 03:45 PM
I had some of these and they both fell off they're total Sh!t the sun gets them hot and they just deform until they come off mine were so twisted they wont even go back on i'm gonna use mastic to fix them on next time but I've gotta get my respray sorted first
Posted 23 July 2015 - 04:14 PM
Tiger seal or silicon should hold them on
Posted 23 July 2015 - 11:40 PM
give the seam a good coating of bilthamber UC clear wax, and then put them on - probably as well to fit new ones which will be in better shape. The wax once set will help to hold them on. If it doesn't, a few blobs of PU sealer should help.
