Balljoints Won't Grease
9 replies to this topic
#1 germini30
germini30
  • 699 posts
Posted 27 July 2015 - 05:53 PM
Had my hubs rebuilt last year with new wheel bearings and ball joints. Went to grease the ball joints the other day put when I put the grease gun onto the nipple I can't get any grease to pump through. The grease gun handle won't squeeze. It seems as though the balljoints grease has gone hard or something. Is that possible?
#2 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 27 July 2015 - 05:56 PM
Have you tried taking the nipples out and trying again? The grease can go hard but easily sorted by dropping the nipple out and gently heating or soaking in solvent overnight.
#3 whistler
whistler
  • 1,818 posts
Posted 27 July 2015 - 06:21 PM
Take the nipples out and attached the grease gun and give it a pump. As Tamworthbay said, the grease could have just gone hard. Once clear screw nipple back in and try again.
#4 nicklouse
  • 18,696 posts
Posted 27 July 2015 - 06:22 PM
Press the nipple end in. It will have stuck.
#5 Blatherskite
Blatherskite
  • 501 posts
  • Local Club: Norsk Mini Cooper Club
Posted 27 July 2015 - 06:55 PM
+1 - possibly due to corrosion. I tapped the wee ball with a small drift & small hammer, then it went fine.
#6 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 27 July 2015 - 07:04 PM
As above, the tiny little ball-bearing in the end will probably be jammed.
#7 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 27 July 2015 - 07:13 PM
regular maintenance prevent bunged nipples..... (snigger) :ph34r:
#8 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 27 July 2015 - 07:32 PM
Or maybe there is no grease path
#9 Spider
  • 15,136 posts
Posted 27 July 2015 - 09:08 PM
Or a tight one!
Are you trying it with the weight on the joints or jacked up?
Try turning the hub through a bit of an angle (yes, I know, not easy with the grease gun in there).
A decent Grease gun will easily make 5000 PSI, so that should un-jam a stuck nipple.
#10 russo
russo
  • 191 posts
  • Local Club: Minis In Nelson Inc.
Posted 28 July 2015 - 04:11 AM
Yup, weight off joints with vehicle jacked up and swivol wheels while pumping grease. You may need to get someone to help you.
