Project Help And Suggestions
5 replies to this topic
#1 we5ty
we5ty
    Starting My Mini Up
  • 4 posts
Posted 27 July 2015 - 07:01 PM
hello all!
I am undertaking the project of my 1991 rover mini city. unfortunately shes a little rusty, so the body and engine are having an overhaul!
i have bought a 1275 A+ engine as its currently running a 998. this is getting my first dose of attention while i sort out the rest of the workshop ready for welding the body
SO HERE IS MY FIRST QUESTION!... ( drum roll)...
i plan to use twin HS2 carbs and a fast road camshaft, however, since im getting the block re-bored to its next size ( piece of mind rather than performance) do i use high compression pistons or standard compression? the plan is to oversize the valves and port and polish the head also... but advice is needed on what pistons to use?
i look forward to your replies!
Westy
#2 carbon
carbon
  • 2,590 posts
Posted 27 July 2015 - 07:16 PM
Are you talking about work on the 1275? If the block is not worn then personally I would reuse as it is.
Check what pistons you currently have fitted, head can be skimmed to raise CR if needed.
What cam are you planning to use?
#3 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 27 July 2015 - 07:22 PM
You need to build the engine to the compression ratio you wish to achieve.
#4 we5ty
we5ty
    Starting My Mini Up
  • 4 posts
Posted 27 July 2015 - 07:26 PM
yes work on the 1275 A+ :)
there is some minor scratching on the cylinder walls so im just going for a rebore.
at the moment it has dished pistons it in, the bloke i bought it off claimed the block was standard with no modifications yet
as for the cam im planning to use one from mini sport, i know its not a kent cam or anything too fancy but i know they are to a good standard and work well
the specs are: Application:    Fast Road
Power Band:    2000-6500 rpm
Valve Lift:    0.318 "
Duration:    252°
Timing:     16/56  51/21
Valve Clearances:    Inlet - 0.015 "     Exhaust - 0.015 "
Lift (TDC):    110°
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 28 July 2015 - 06:50 PM
252° 'fast' road?
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 July 2015 - 09:12 PM
I would at least use a kent 266 the modern version of the MG Metro cam, then you will have a nice road engine if the Heads done right, the secret to any power in a A Series always comes back to a good with good CFM, put what cam you like in its the head which allows the air flow into the combustion chambers
