Carb Needle
8 replies to this topic
#1 MiniHead95
MiniHead95
  • 168 posts
Posted 28 July 2015 - 10:22 AM
Hello,
Wondering what carb needle to go with, been suggested a BBW,here is the spec for the engine and carb.
Hif 44
Engine:mg metro 1275 +40 (1310)
Omega 6.5cc dished pistons
276 cam
1.5 roller rockers
Ported and flowed mg metro big valve head
(will have a standard dizzy to start but will be upgraded to a aldon yellow)
Think that is everything listed that would affect the needle size, can supply more info if needed.
Cheers.
#2 jaydee
jaydee
  • 8,565 posts
Posted 28 July 2015 - 10:37 AM
Needle requirement will be different if youre using a stadard air box or a cone filter or even better a filter with a stub stack inside
BBW + aldon yellow can even work but to get the most out of it your best bet is investing money on a rolling road session with you standard dizzy to get the advance curve tuned correctly and to have a custom needle reprofiled.
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 July 2015 - 10:40 AM
H&H ignitions could reprofile you distributor for about £40 they have done a couple for me on customers cars 01384 261500
You'll struggle to find a Rolling Road that can reprofile the actual curve, and the cost on the day would be massive.
Edited by KernowCooper, 28 July 2015 - 10:41 AM.
#4 MiniHead95
MiniHead95
  • 168 posts
Posted 28 July 2015 - 10:51 AM
Yeah im going to get a rolling road done where a needle can be filed down, but for first start what do you recommend? Just so it isn't too lean or rich for that matter
#5 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 28 July 2015 - 11:33 AM
£45 inc. return p+p
#6 jaydee
jaydee
  • 8,565 posts
Posted 28 July 2015 - 12:29 PM
The low down on these standard SU profiles is that once you set the right idle, they end up too rich at mid range and too lean at tops, probably a consequence of modern fuels?
I think BBW can be the best choice for starting, can be a personal preference but imho it can be much better than profiling a BDL needle since with a BBW you have more meat to play with when adjusting the cruising speed stations
#7 MiniHead95
MiniHead95
  • 168 posts
Posted 28 July 2015 - 12:30 PM
Oh alright, so you send off a standard dizzy and they put weights in it to get the curve you want?
#8 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 28 July 2015 - 01:21 PM
Give them a bell: http://www.h-h-ignit...olutions.co.uk/
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 28 July 2015 - 03:17 PM
Yes you include the spec of your engine Cam,C.Ratio, Head and they are like Aldon who have done so many they have a list of what works, Aldon has the biggest list of curves for dare I say every spec done on their rolling road over the years, H&H will yes select the weights and set the maximum advance and select the primary and secondary spring rates.
