Brake Pads
Posted 31 July 2015 - 06:03 AM
I have the minispares 4 pot alloy ones, what are good pads for these? Can't bring myself to buy the green stuff ones as they are £50 and there are so many difference views on whether green stuff are good.
So what do people recommend?
Posted 31 July 2015 - 06:54 AM
Posted 31 July 2015 - 07:12 AM
I recently changed from Greenstuff pads to 1144's, my experience fitted to a weekend toy -
The Greenstuff pads are terrible when cold but don't deposit loads of dust on the wheels
The 1144's are amazing when hot but I struggle to keep the heat in them the big downside though is the brake squeal at low speeds
I'd suggest you just stick with the standard pads plus they're cheaper - http://www.minispare...px|Back to shop
Posted 31 July 2015 - 07:13 AM
that's because of changes to EU regs on formulation. Cooperman suggested 1144s to me and I have never experienced braking like it on a mini. They are superb BUT they do squeal a bit! They are what will be going on my project.Heard people say mintex m1144 are really good, but looking at them they say they are race pads
Posted 31 July 2015 - 08:51 AM
to be honest the 1144s are too noisey for a road car
Brake pad squeal is acceptable for a rally or trackday car, but really annoying for a road car
Posted 31 July 2015 - 11:26 AM
I just switched my green stuff pads (minisport 4 pots) for standard mintex pads and so far (although its not been driven in anger) they are much better than the green stuff pads ever were.
Posted 01 August 2015 - 09:27 AM
Just as brakes getting too hot in use can be a problem, so can brakes running too cold.
If you are running 4-pots and maybe vented discs (although not necessarily so) you may need a softer pad unless the car is for competition. For road cars the best brakes for a light car like a Mini are standard discs & callipers with up-graded top quality pads. For 4-pots on a road car with solid discs standard good quality Mintex or Ferodo would be ideal.
Posted 02 August 2015 - 10:14 AM
Posted 07 September 2015 - 07:11 AM
I ran ebc's yelowstuff pads which were great after about 5-10 hairy miles, then swapped to mintex which were better but still not brilliant out of the box so bought some pagid pads which other than the brake dust I have no complaints about. Also running 4 pot calipers with solid discs under 10in wheels. 70-0 is surprising :)
Hey mate, I'm running the minispares alloy 4 pot calipers, can you recommend the pagid pads? If so where did you get them from? Cheers
