Buying Preverto Parts, Noob Question
10 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 01 August 2015 - 11:47 PM
Hi peeps!
I'm converting from verto to preverto, do I need to buy the pressure plate seperate from the diafragm?
Or do they come 'paired'? As it looks that there is already a plate attached here on this ebay add?
http://www.benl.ebay...=item1c1b1ad534
(will buy from minispares so if anyone bought there recently... or if simon is online and reading this.. :D )
Cheers!
Edited by Dusky, 01 August 2015 - 11:49 PM.
#2 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 August 2015 - 12:20 AM
Thats a complete Diaphragm assembly ready to bolt on, you have all the other stuff ?
#3 Dusky
Dusky
  • 5,322 posts
Posted 02 August 2015 - 05:12 AM
I have yet to buy everything :/
This is what I was planning on buying for the flywheel :
Would C-AHT230
  be obsolete then? :P
many thanks!
Product description Quantity Status Unit price   Subtotal
C-AHT230 - PRESSURE PLATE LIGHTENED EN8 FOR COMPETITION PRE VERTO
   DAM5923 - FLYWHEEL KEYWAY LOCATING PLATE A+
 2A3659 - CLUTCH FLYWHEEL STRAP BOLT SHORT-torque to 16lbs only 3 transparent.gif
  2A3657 - CLUTCH BOLT LONG COVER TO PRESSURE torque to 16lbs only 3 transparent.gif
  C-AEG420 - STEEL FLYWHEEL - C-AEG421 TYPE FOR PRE-ENGAGED STARTER 1 transparent.gif
              13H300 - RUBBER CLUTCH HOSE FOR PRE VERTO UP TO 1982/3 1 transparent.gif
Edited by Dusky, 02 August 2015 - 05:13 AM.
#4 Spider
  • 15,201 posts
Posted 02 August 2015 - 06:29 AM
Dusty, you'll need all these items (some I know you already have on your list);-
Flywheel
Backing Plate
Lock Plate - Flywheel to Crank
Flywheel Bolt (goes in to crankshaft) (can someone confirm on this?)
Flywheel Drive Straps (6 in all)
Flywheel to Strap Bolts (3 in all)
Lock Tabs for above (3 in all) -  I prefer loctite
Backing Plate to Strap Bolts (3 in all)
3/8 Internal Star Washer (3 in all)
Pre-Verto Clutch Kit, which includes;-
    Clutch Plate (pre-verto)
    Diaphragm
    Clutch Release Bearing
Plunger (Pre-verto)
Clutch Over-thrown Nut (screws on the above)
Lock-nut for above
Clutch Arm (Pre-verto)
Clutch Return Spring
Clutch Return Spring Anchor (goes on Arm)
Small Clevis Pin - goes in top of Arm and also retains above
Large Clevis Pin - goes through Clutch Cover and Clutch Arm
Clutch slave Cylinder Hose (pre-verto)
I think that covers it.
In respect of the Orange Diaphragm, I'd suggest a Blue one would be fine for your engine, I use them in street engines up to around the 105 HP Mark without an issue, going to a heavier one only loads up the crank thrusts more.
Apparently you can use your Verto Slave Cylinder.
Edited by Moke Spider, 02 August 2015 - 08:26 AM.
#5 Dusky
Dusky
  • 5,322 posts
Posted 02 August 2015 - 11:27 AM
Flywheel
Backing Plate
    Diaphragm
Plunger (Pre-verto)
Lock-nut for above
Thanks!
Would be a Nice saving to retain the verto slave!
How Many drive straps do you advise? 6 is standard i think? Trying to cut the costs a bit :P
Oh, and do you know about a pre verto clutch being used with a verto arm? Have heard some stories here in a local club about some cars comming like that, though no one could verify this :P
Many thanks!
#6 carbon
carbon
  • 2,590 posts
Posted 02 August 2015 - 11:47 AM
Dusky, I would stick with 6 straps but make sure they are all matched.
#7 Dusky
Dusky
  • 5,322 posts
Posted 02 August 2015 - 11:54 AM
When you buy them new, are they matched? Or do i need to machine /file them for any clearance orso? :)
#8 carbon
carbon
  • 2,590 posts
Posted 02 August 2015 - 07:31 PM
If you get 6 new straps from the same supplier they should all be the same.
Easy to check, use one of the clutch backplate retaining bolts, and fit the 6 straps over the shoulder portion. Line all of the straps up together, and using a second backplate bolt try pushing this through the second strap hole. The shoulder portion should slip through the second hole on all of the straps if the distance between the holes is the same for all 6 straps.
#9 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 02 August 2015 - 08:20 PM
Why are you changing ? the verto clutch can take a lot of power
#10 Spider
  • 15,201 posts
Posted 02 August 2015 - 08:45 PM
As Carbon said, the straps usually are pretty good, but YES check them.
Can one of you guys confirm if a different flywheel bolt is needed?  I know from production, the vertos had a different bolt, what's the difference between them?
Also, just be aware that some of the lightened Flywheels need additional spacers to go between the Flywheel and the Drive Straps. You'd have to measure what's needed but if they are not supplied with the flywheel, they are usually 4 to 6 mm in thickness for a guide. Some of the flywheels already come with them.
#11 Dusky
Dusky
  • 5,322 posts
Posted 02 August 2015 - 10:48 PM
Im wondered about the bolt too, as Im using loctite anyway :)
If someone could confirm anything about this it would be great! ;)
Will have a good look into the drive straps, ik all new to this so give me some credit xd
Im changing because of the ease to get a lightened flywheel for it, im only going to road light from minispares though, not the ultra super deluxe feather weight :)
