Stainless Nuts And Bolts?
16 replies to this topic
#16 Spider
  • 15,685 posts
Posted 01 September 2015 - 09:18 PM
How does one use loctite and copper grease?
Put a drop of loctite on the end 4/5 threads then using a small brush put copper grease on the next few threads...
But as you thread the bolt in you smear loctite all the way down the thread. Seems like a one or the other. Either you want the fastener to stay, or you want it easy to remove.
Why not try it for yourself and see if it works?
#17 paulsv24
paulsv24
  • 44 posts
  • Local Club: Essex Mini Club
Posted 02 September 2015 - 07:44 AM
Although SS is softer there's two grades A2 and A4 (A4 being more expensive and better quality). I used to work in a marine workshop and due to corrosion etc all we could use was SS and they never failed. Bare in mind, it is softer which would mean, if it's a bolt that will have to be undone in the future quite often then there would be a chance of the head gradually rounding or thread stretching. We did used to renew them quite frequently.
