drove up a drive way that had a shitty gate centre support!!!!! it caused the downpipe to blow and the intake
so heres my fix sorry new to this will get better at posting I'm always fixing our classic minis.
1. Jack car up correctly and safely onto Axle Stands.
IMG_1110.JPG 52.76K
30 downloads
2. Now you need to free the down pipe from the intake manifold 3 nuts (imperial) 1/2 hex shape works best with 1/4inch drive. Also their is one nut that is hard to get to you will need a UJ to get in on the angle. Also excuse my horrible extension set up ;)
IMG_1114.JPG 65.42K
24 downloads
IMG_1116.JPG 50.64K
37 downloads
3. Now the downpipe is free it will be ok to rest on a old box, Now to top of the vehicle Remove the famous Injection air box by the 3 philips screws.
IMG_1119.JPG 59.51K
14 downloads
now you should have something like this
IMG_1120.JPG 33.7K
22 downloads
4. next step is to lube up with your favourite lubing solution
IMG_1121.JPG 64.33K
11 downloads
5. now start to remove all loom connectors i.e. injector electrics 02 sensor all things that would stop you removing the intake.
IMG_1129.JPG 47.23K
17 downloads
5A. remove air box support bracket 5/16 socket
6. Now remove fuel in and return lines also a 5/16 socket once lines are removed put them out of the way where their is no paint as petrol will spill out.
IMG_1135.JPG 54.57K
18 downloads
7. time to remove manifold nuts now easiest way is to use a gear wrench 13mm to remove not to worry if the studs come out we can lock to nuts together and break them free, Also on the far left and far right they have 2 13mm different shape nuts with washers careful not to loose them the middle ones all all uniform with a thick back to them.
IMG_1137.JPG 74.3K
18 downloads
8. to remove the manifolds you have to remove the intake first give it some persuasion then lift out a problem i had was the brake servo line don't know how to remove the line so not going to brake anything trying so i have sat manifold up out of the way still connected to the servo. Now time for exhaust bit more tricky for me their is vacuum vent pipes connected to the heat shield you have to remove 2 bolts one from the exhaust heat shield i rounded mine so left it in place but left me having to remove vent pipes with the manifold.
IMG_1138.JPG 64.34K
25 downloads
IMG_1139.JPG 61.61K
18 downloads
look how much meat in on this manifold in need of a port and polish job soon ;)
IMG_1140.JPG 65.57K
15 downloads
9. time for clean up of parts i removed the stubborn heat shield bolt and wire wheeled all my nuts ;) then gave the exhaust a touch of VHT paint. Made life easy and fitted the vent hoes back on now that i got them free,
10. time for new gaskets then follow these steps in reverse order. USE YOUR HEAD BE GENTLE
HALFRAUDS home kit was all i used.
IMG_1113.JPG 72.47K
13 downloads
IMG_1141.JPG 66.82K
18 downloads
Thanks Jordy
