Coil Lead Screw
4 replies to this topic
#1 1963MKI
1963MKI
  • 163 posts
Posted 05 August 2015 - 05:26 PM
I broke the small plastic screw that holds the lead from the dizzy into the coil. Any ideas on where I can get a replacement ? or just a good fix that bypasses the need for it, such as soldering the lead into the coil ?
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 August 2015 - 06:40 PM
I do not understand which part is broken.  Can you post a picture of the part?  If not, can you find a similar picture of a coil and dizzy and post a link to it with text explaining what part broke while referring to the picture?
#3 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 05 August 2015 - 06:47 PM
Sounds like a early coil Doug with the screw in fitment on the coils HT lead, they used to come with the coil, you can buy a new coil here, http://www.simonbbc....67219928ed71b45
unless you can find one then you cant really solder the lead in.
  • Attached File  $_1.JPG   17.74K   8 downloads
Edited by KernowCooper, 05 August 2015 - 06:52 PM.
#4 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 05 August 2015 - 08:05 PM
Make sure you buy the correct length as the acorns as they are called come in two different lengths and you need the long one for a coil, not one for a distributor cap.
#5 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 August 2015 - 08:23 PM
It never occurred to me that this could be a 1960s coil.
I found the part listed as 408120.  I found several new and used ones on eBay.co.uk.
and... new at AES
http://www.autoelect...coil-1929-p.asp
I have bought from AES before.
and at Holden.co.uk
http://www.holden.co...sp?pCode=408120
Edited by dklawson, 05 August 2015 - 08:24 PM.
