Mini Starts But Won't Run
Posted 05 August 2015 - 06:54 PM
Posted 05 August 2015 - 07:23 PM
Running weak - air leak ? start it and spray wd40 around the inlet and carb gaskets see if it revs up
Posted 05 August 2015 - 08:02 PM
Posted 06 August 2015 - 12:20 PM
You said that you have just fitted a new HS4 and that you have fitted a new head gasket. Did you adjust the valves after fitting the new head gasket? Did you double check the torque on the head studs? Did you make sure the gaskets are properly in place for the carb to manifold as well as the manifold to head that you already looked at? Did you make the basic carb adjustments to get the engine to start or did you simply bolt the carb on right out of the box?
Posted 10 August 2015 - 03:43 PM
Posted 10 August 2015 - 04:09 PM
Check that the carb piston can rise and fall freely. If you have a brake servo, check its hose carefully for splits that might let air leak into the intake manifold. And... since the head gasket is new, run a compression check on the engine to make sure the new gasket is doing its job.
